I am installing a garage utility sink and have a question about connecting my sink drain to the existing ABS drain line from my washer. I was thinking a double sanitary tee might do the trick but I can't seem to locate one that has the right size openings. As you can see by my attached picture the inlet from the washer and the vent line on top are both 1 1/2" but the drain out is 2".
Any ideas on what I should do to plumb the drain in? Thanks in advance for your responses.
E Busby
E Busby
