View Full Version : Wallmount carrier 'accessories' needed
aviator_edb
05-31-2008, 01:50 PM
I have a new Glenwall (http://www.terrylove.com/forums/showthread.php?t=25073) wallmount toilet which is replacing an older wallmount toilet. I'm using the existing carrier support. The trouble is we have lost the washers and nuts to hold the toilet on! I believe we have a Wade carrier system. I 'think' it's a ade 380 but this carrier is from 1968 so I cant be 100% sure. It 'looks' almost exactly like pictures of the 380.
Anyway, is there an accessory kit that contains the nuts and washers? Where can I get one? If I cant get the accessories alone will I have to buy an new carrier just to get those items?
Also, where can I get the new gasket? I've looked online and the big box stores all looked at me like I had three heads when I asked about them...
Thanks for all help
http://www.terrylove.com/forums/attachment.php?attachmentid=4571&stc=1&d=1212522363
05-31-2008, 02:58 PM
For the nuts and washers, hardware stores will carry generics that work.
For the Chrome cap nuts, I've never found anybody that sells them.
I would contact either Zurn or Wade and see you they can supply you.
The gasket is either a Zurn Z-120-57 or a Plumbest 71398
05-31-2008, 03:42 PM
The acorn cap nuts are "generic" so any carrier distributor will have them and the gasket, usually in a bag with the rest of the nuts, metal washers, and fiber washers, (don't forget those).
aviator_edb
06-02-2008, 12:50 PM
OK, In case I have to scrounge for the washers and nuts I want to be sure I have the assembly order correct.
On the mounting studs I place a 5/8" nut and washer. The top right stud has a 'funky' washer that threads onto the mounting stud. There is no nut.
Level in same plane so there is at least 1/16" clearance between wall and toilet.
Set my gasket.
With help place the bowl onto the mountings studs.
All but top right stud gets a felt washer and 5/8" nut and tighten.
FIRST QUESTION: How tight? I'm guessing it would be pretty easy to crack the porcelan?
After first three nuts are tightened add the top right fiber washer and nut and tighten 1/4 turn after finger tightening.
Next question: Am I correct that there is NOT a metal washer on the outside of the bowl.
thanks for the help.
