leanto442
04-30-2005, 08:40 PM
My pump has been working fine in the past, but today I had low pressure. When I went out to look in the wellhouse, there was a leak in one of the lines from the well. I replaced the piping, and as far as I can tell there are no further leaks. After bleeding the pump, it runs continuously, even after reaching the 40 Psi it typicaly stopped at. The pressure will not go higher, but it still runs, staying at that pressure. I turned on water inside the house, and there was still poor pressure, that gradually got worse in less than ten minutes. The pressure on the pump dropped then, and I had to let it get back up. I turned off the valve that closes all the outgoing lines, thus limiting the water in to staying in the wellhouse pipes, but the pump still ran, and a few minutes later the pressure dropped again, this time forcing me to bleed it again.
I can't figure out what's going on. There are no leaks that I can see, after looking at the pipes and checking under the house, but the pump won't shut off. I also made sure the cut off switches could flip, so them being stuck isn't a problem. Does anyone know what it could be? Thanks
