Jd
04-30-2005, 03:20 PM
Hello:
I seem to have air in the hot water supply lines at any 3 of my sinks. It will clear from any one that I initially open.This is all new construction. A two story garage with 2 sinks on the second floor and 1 slop sink on the first floor. There is air trapped in only the hot water supplies. It takes about a minute for it to reach the hot water faucet, so I think it is air trapped near the gas fired hot water heater. This happens everytime I if I do not use the hot water for an overnight period. Two days w/o using it and it would have even more air to purge. I do not smell any odor from the air purging from the faucets. As far as I can tell I have no leaks in any of the lines.
Any suggestions?
Thank you
Jd
Any suggestions?
Thank you
Jd
