Tapping an old well
Mr G
Notasulga, AL
I have tapped an old well (6" drilled) on my property which is about 80 feet deep. When I dropped the submersible pump into the well we hit mud and silt. We shorten the line about 5 feet and we are getting water but running one water sprinkler pulls the water down in about 25 minutes. Is there anyway to remove the mud and silt from the bottom of the well?
Thanks
You can air lift it if you run a 1" or larger pipe to the bottom to get the air to the bottom of the well, and then have a very large air compressor, like 85+ cfu, to dump a lot of air into the well and blow the water and dirt out the top of the casing. Or, you need a bailer, a long length of 3-5" pipe with a foot valve to drop to the bottom of the well, fill with water and dirt and pull it up and dump it and go back for more. It's called purging.
