Help Well Not Workin!
vixen_00800
Ok heres the problem. Get up this morning and little water pressure, of course I didnt know it till i started the washing machine and it trickled and trickled. I started to wonder what in the world is taking so long filling the washer... duh theres no water pressure. Check all the hoses for crimps then i go to the shower.... no pressure there either. Check all outlets and make sure they are off , out and in. Everything looks normal. CHeck the well house, water pressure but barely. Whats the problem? Well out? Well dry? Hubby won't be home till late, Can i check something myself??
Is the pump visible or a submersible in the well?
Is/was the pump running?
Other than that, there's little to do other than conserve water unless you can do electrical tests on the pump etc.. You could call a pump guy or well driller, or only a plumber that is capable of pulling the pump if it is a submersible.
well its in its own house and everything is surrounded by insulation in there. can't see a darn thing, but I can't hear the pump running either.
well its a good thing he is both.... but i called him and he said he will come test it. I hope its something simple.... I know most likely not...
