lift bucket style drain won't stay closed
trex604
Our bathtub drain won't stay open suddenly and you can watch the lever slowly come up and close the drain. What could be going on? I found the diagram online and can't see any reason for it to suddenly start closing. How do I correct it? Thank you.
Dave
Thank you for the input. I went out and got one and will attempt to put it in over the weekend. Never worked on the tub mechanism before so this is a first.
Dave
drain
Remove the two screws. Pull the mechanism out. Remove the small brass cotter key. Throw the old plate away. Connect mechanism to the new plate with the brass cotter key. Reinstall and tighten the two screws.
mission accomplished
Thanks again for your advice. Everything went very well and I didn't let the rod slip back down while changing the lever. Now I know something else for the future. This is a great forum.
