Water pressure
davis
When we turn our water on; it will follow with high pressure and then drop in pressure. Also, the toilets will flush sometimes automatically.
that's not much info to go on...
Do you have a pressure-reduction valve? Have you hooked up a pressure gage to see what your pressure really is?
Is this on a well, or a municipal water system?
That is the difference between static and dynamic water pressures. Static is always higher than dynamic, meaning when you run water. That's because of the pressure loses in the plumbing system, and when you can notice the decrease, you usually have low static pressure and/or a partial blockage somewhere in the system.
So answer the other guys' questions and we can go from there.
I have a drilled well ~200 ft. I am not sure about the pressure reduction valve - the only thing I could find before my air tank is the pressure gauge.
It sounds like your bladder tank needs service or replacment. With a well, it is doubtful you have a PRV. Look at the pressure gauge while someone opens a faucet. My guess is that the pressure drops almost immediately and then the pump turns on. If so, this is an indication that the bladder tank is not working properly. It could be that the bladder is shot, or it has lost its pressure charge.
Turn the pump off, open a valve and let the water run until it stops, then take an air pressure gauge (tire pressure gauge) and check the pressure on the bladder tank. If your pressure switch is set to say 30-50, then the tank static pressure should be set to 2 less than the lower number, or 28#. If you get water out of the air filler, the tank is shot. If you don't, pump it up as required. Let it sit for about 10-minutes and recheck to see if it held. If all is well, turn the pump back on.
