The new Toto Promenade
1923
Does anyone here have experience with this toilet? Although I know it's not as good as the higher end Totos, and doesn't have the Gmax flush, the base isn't as wide as the the others and so it doesn't look nearly as modern to me. It doesn't have any ratings I can find (every toilet I like doesn't have any ratings, even the Toto!). Thanks again.
attachment.php
The new Toto Promenade CST424SF comes with G-Max and comfort height.
The one I'm looking at is the current Toto Promenade Round Front--it has the lower (not "comfort height") seat.
I tried looking here: https://www.map-testing.com/
but this model isn't listed with all the other Totos.
Some old, some new
The old Promenaded on the Toto site is:
The Toto Promenade, CST723 is a round front bowl, using washdown flush. The tank on this is a ST723, which uses the 2" flush valve. $231
The new Promenades that have a siphon flush are:
The new Promenade is a very good toilet.
Good flush, performance, trapway, and a nice clean flush.
The new Promenade on the web site has a bumped up number.
CST424SF, G-Max 3" flush valve, Promenade, 1.6 gallon flush, comfort height bowl, elongated. $336.00
or
CST424EF, Eco 3" flush valve, Promenade, 1.28 gallon Eco Flush, comfort height bowl, elongated.
These with the siphon flush work efficiently and with little muss.​
If you get the Promenade, I would recommend the new models.
Notice the improved trapway of the CST424SF model.​
Interesting. I didn't write down the number of the one I was looking at, but if it's not the G-max, I'll make sure to find the new one. At this plumbing store (not a big box store), they told me that the St. Thomas Creations Richmond and the Toto Promendade flushed equally as well, except the Toto wasn't comfort height. The Richmond would match my other fixtures better, but I tested the store's Richmond in as it was their choice int restroom and wasn't that impressed. There was so little water it was rather disconcerting!
Thanks for this forum and the info. I never knew I would find a true need for such a discussion, but a lot has changed in toilet world in the last few decades. I didn't even know that finding a round bowl would be practically impossible....
The Dartmouth, Whitney, and Clayton would be three more G-Max choices.
