Accident. Need help
Willl
North Dakota
So I have just solvent welded expensive PVC gate valves to 2" PVC pipe.:mad: Can I cut the pipe and the some how remove the 2" pipe from within the slip socket that is on the PVC gate valves. The PVC gate valves have slip sockets on each end to allow 2" pipe to slip inside. Thanks
They sell a drill bit expressly to ream out a fitting, it's not too expensive, but you'd have to compare its cost to just starting over with new parts. Other than that, you'd probably not get it apart and useable.
First suggestion would be to cut the pipe leaving a couple of inches. You can then join the valve into wherever you need to use it using appropriate couplings.
If you must reuse the valve "as new" you will need to get a fairly expensive drill called a "ram bit" to drill out the pipe from the socket.
I was planning on making a hat out of them. NOT. Really though right after the valve there is a Tee and that tee has to be at a very precise angle inorder to fit in the assembly that I am constructing. I gotta slow down. Thanks for all the replies.
2 valves at 30 dollars each. I think I might just redo it with new fittings just to make sure it is done right. Thanks
Cut the pipe about an inch from the valve and then make a series of vertical cuts in the pipe (hacksaw, dremel, sawzall), but be careful not to cut the fitting, and then see if you can peel the old pipe out of the valve fitting. It takes some time and you may need to sand old glue/solvent out of the female socket when you're done. Use a good aplication of primer and glue when you put it together again because it may be slightly deformed but it usually works for me maybe more than half the time. Probably not a good idea for high pressure applications.
