Trouble with pressure balancing valve
jasdyer
Just bought a house that had been "winterized" for about 8 months. After de-winterizing all was well EXCEPT I get ZERO hot water flow from one of the Delta pressure-balancing tub/shower valves. It's about 15 or so years old. Any advice on where to star looking for the problem??
Your balancing spool may be stuck. It shood be located behind the face plate of the faucet. It looks like a 1" diameter slotted screw.
Thanks Crow
Let's say I find it and assume that it's stuck. Now what? Hammer, screwdriver, wd-40? How do I unstick it?
1)You can try tapping on the large screw (Sometimes it will unstick).
2)You can shut off your water and try to unscrew that large screw. Once its out
------a) Try tapping the entire spool on something hard and see if it loosens
------- b ) purchase an identical balancing spool and replace it
---------------- i) maybe HD
-------------- ii) plumbing supply house
---------------iii) call delta for replacement part
Thanks, again, Krow!
Will do! I was kidding about the hammer! Guess I might use it after all. I appreciate the tips.
