rstier
04-25-2005, 05:45 AM
Hi,
I just moved into a 10 year old home that has a Trianco tankless 3 zone oil burner system (Beckett Burner). When I go to take a shower, the first minute produces more than adequate hot water temperature. After that, the temperature slowly goes to luke warm, even with the shower valve turned all the way to hot. At some point, it does become hot again but only for a short time. I am the only one using water when this happens.
This doesn't appear to be a mixing valve setting because the initial temperature is fine. My previous home had a gas burner with a 50 Gal hot water tank, so this is a new experience for me. As I mentioned, there are 3 zones. 2 of the zones are for baseboard radiators and the third is for a radiant floor system in our family room. Any suggestions on what may be causing this?
Ron
Ron
