stamp
College Professor
I removed a bathtub and there was a metal pipe (thin walled type) running from the tub drain to an ABS pipe. My access was not great, and so I had to use a bit of force to remove the metal pipe from the ABS pipe (after I had removed the plastic compression fitting). Now I notice a small amount of side-to-side movement in the ABS pipe, which seems to occur at a compression fitting that's near (or part of) the P trap. The fitting itself is very tight (I certainly can't budge it by hand), but I can move the pipe back and forth. Is this normal? I'm just wondering if I might have damaged something down there and it's difficult to see much. I ran some water down it and there was no obvious problem. Any suggestions would be appreciated. Thanks.
