Sewer Gas Problem
Ewstan
Ladies and Gentlemen,
I have a toilet installed on a tile over concrete floor. The flange is approx 1/4" above the tile. The floor is reasonably flat requiring slight shimming, 1/8", at front and right front. After installation the toilet is level and does not rock.
Over the past 10 years I have reset the toilet at least six times due to sewer gas leaks. The gas leak can return anywhere from two years to six months after resetting.
I have used all thicknesses of wax seals, seals with and without horns, seals with and without foam. It's almost as if overpressure in the vent system is blowing out the wax seal, although I don't see how that's possible.
Today I'm going to try the slip joint/rubber O-ring seal, but have little confidence that it will work.
I don't see any problem with the toilet horn and the bottom of the toilet is flat.
Any suggestions?
Thanks,
ewstan
Agressive use of a plunger can blow out a wax seal. Is the flange sitting tight to the finished floor? About 1/4" is the typical height of the flange itself, but if it has a gap underneath of 1/4", that could easily be your problem. Many modern toilets will not seat on a flange that high if there is a gap underneath. If yours does, there's very little if any wax making the seal (but it would be hard to blow it out!).
Do you have frequent clogs requiring the use of a plunger? I have several of the Fluidmaster waxless seals, and they've worked for me.
Are you double bolting the closet bolts, once to the flange and then once to the toilet, using your bolt caps and caulking???
This must be because of improper installation, if the flange is 1/4" above the tile, it is proper, and wax is the only sure thing to work.
Fluidmaster has some extending piece of crap out there ont he market, don't use it;)
The Fluidmaster is pushed onto the horn of the bowl first.
To add more info:
I removed the toilet and noticed that the wax ring was not stuck to the toilet and that the top of the wax was wet.
I cleaned the wax from the flange and, not sure why I never noticed this before, discovered that the ABS pipe in the concrete is not vertical. Consequently, the flange glued to the pipe is not level. The left/left front is approx 1/4" lower than the right/right rear.
Is there a flange that's adjustable for level? Or should I try two wax seals to try to compensate for the off level flange?
Thanks,
ewstan
Try a double wax ring, or the waxless. Are you sure the tilet is not hitting the flange and that is what is causing it to not sit level? If that is the case, you need to fix it, but the waxless probably would work.
the toilet flange should be sitting on TOP of the finished floor with NO gaps under it.
I've had one of the Fluidmaster waxless seals for a couple of years and decided dry fit it to the off-vertical pipe. It appeared to be able to compensate for the slight off-vertical pipe while maintaining a good seal in the pipe and at the toilet horn.
So I installed it, slightly shimmed the toilet and bolted it down. No gas smell now, but I'm going to let it sit overnight before putting the tank on. Hopefully this will solve the problem.
Thanks,
ewstan
I assume you put some water in the bowl, or you did not cap it.
