neo angle shower drain question
johnnyhomeowner
i have remodeled my bathroom and its time to reconnect the shower drain
when i was tearing out i cut off the shower drain about 6 inches from the waste pipe tha the toilet and shower go in and capped it off til i was done
my question is when the pipe leaves the shower i know it goes down to a p-trape then over to the waste pipe
how far down from the drain do i put the p-trape
and what amount of fall do i need from the trap to the waste pipe
any help would be greatly appreciated
There is no set depth for the p-trap to be. Just make it comfotable for you to work with. It also depends on the elevation of your branch line (main drain where it connects to)
General rule of thumb, 1/4" per foot or 2% slope
so the fall on the drain line would set the p-trap distance
the main drain is about 6 inches from the ground
from the drain to the subfloor is about 24 inches
from the drain to the main drain is 4 foot
so i need to get the drop right from shower drain to main drain then p-trap and straight up to shower drain?
This 1/4" per foot applies from the P-trap to the vent. After that, you can have the drain going verticle if you wanted. The vent has to be within 5' of the p-trap
