View Full Version : Garden Hose....diameter vs. outlet feed
chefwong
04-22-2008, 08:43 PM
The pipe leading to my outside water source is 1/2" brass.
If I use a 3/4" garden hose as opposed to 5/8", is there any extra added benefit ? Or is it a cumulation of hose length, water pressure, ID of the hose in relation to ID of the brass pipe, etc ?
Furd
04-22-2008, 09:59 PM
Every inch of pipe, tubing or hose contributes to pressure drop and a reduction of flow at the end. Using the 3/4 inch hose will reduce the pressure drop across the length of hose. The longer the hose the more pronounced the pressure drop will be; therefore, using a 3/4 inch hose will have less pressure drop (and consequently a greater flow rate) than using the same length of 5/8 inch hose.
04-23-2008, 07:24 AM
The size of the hose is often immaterial, because the amount of flow is limited to what the orifice in the hose's faucet can deliver. Since that opening is usually a 3/8" hex, or less, that is all the water you will get as long as the hose is large enough to deliver that amount.
