flexible tubing instead of compression fitting?
stamp
College Professor
Los Gatos, California
www.cs.sjsu.edu
I have a wall mount faucet for a clawfoot tub. It's supposed to use compression fittings to connect to 1/2" copper pipe. However, I'd like to connect flexible tubing instead of the compression fittings, since I'm installing the faucet on a movable stand. The 3/4" flexible tubing that is used on water heaters will fit in place of the compression fitting. Is there any potential problem using the flexible connectors instead of the compression fittings?
If you'd like to see a schematic of the faucet, it's here:
http://common.csnstores.com/common/marketing/elizabethanclassics/1317tech.pdf
Thanks.
I cannot visualize what you are trying to do but I would like to make a few comments.
1) I would not use flexible connectors if they are to be installed behind a wall.
2) You should not use compression fittings behind a wall.
3) The braided stainless steel water heater flexible hoses are actually not very flexible (far less than the smaller ones more commonly used for faucets and toilets). If you need to bend them a lot, they will crimp very easily obstructing flow and potentially damaging them.
clarification
The flexible tubing will be attached in place of the nut that is supposed to hold the compression thing in place. Also, none of this will be behind any wall, and it does not need to be very flexible (I just want to be able to move it a little bit and the 18" water heater tubing would be ideal).
