biking_viking
04-18-2008, 07:29 AM
I'm running some 1/2" Pex for radiant panel heating through a wall. Since the wall is 2x6 construction I assume it is load bearing. I have access to the top 7” of the wall, just above a fire block made of horizontal 2x6. My questions are:
1. Should I run the supply and return Pex through the same hole (probably 1 ½”), or two separate holes (probably two ¾”)?
2. There is already an electric cable through some of the studs, is it ok to have three ¾” holes in the same top 7” of the stud?
