Changing escutcheons and handles
wgriffin
have Delta fixtures in a tub and a shower both work fine. I am interested in changing the look and wonder if a more modern set can be installed without changing the valve stems. These are dual handle models that set to each side of the filler in the tub and the same in the shower. If this cannot be done is there alternatives without tearing out the plumbing? Thanks for any help
Delta
The only way is to find a Delta faucet that you like better and then use its parts to upgrade yours. The only problem might be if yours is very old and has a different method of securing the trim flanges.
