View Full Version : tankless heater for very small house
bukzin
04-19-2005, 08:58 PM
Need new water heater, thinking about a tankless system.
Here are some details:
total remodel of 600 sq. ft. house (40 year old gas unit gone)
large clawfoot tub
both natural gas and 220volts (200amp) available
one occupant (no kids)
located in northern Calif (very mild winters)
What else is relevant to weigh the choice?
I have done a fair amount of reading on the pros and cons
but am having a hard time picking a path.
Thoughts?
Bukzin
master plumber mark
04-20-2005, 04:11 AM
They are really not all that reliable for a lot of reasons,
though you are living by yourself and are more eligible to
tolerate one than a full family could.
Click on this link then
go to the bottom of the page and their is information about tankless water heaters that might sway your opinion about them
http://www.weilhammerplumbing.com/products/
have fun
jimbo
04-20-2005, 06:50 AM
You mentioned a tub. If you are fond of baths, as opposed to showers, it would take 15 to 20 minutes to fill a tub, since a small tankless puts out a very low gallons per minute.
If you take showers only, the tankless would suffice, but you must decide if the high initial cost and I believe long payback period are worth it. Couple that with high installation cost, and much higher normal routine maintenance required compared to a regular WH....you decide.
mrjetskey
04-20-2005, 10:40 AM
My father now lives alone in a 1100 ' home with one bathtub.He has a small 20 or so gallon electric hot water heater.under the kitchen cabinet ,it way more than suffices for the bathtub and dishwater.plus you can fill the tub fast.very cost efficent for 1 person. JMHO. ps.I owned a tankless water heater and the are fantastic when they work.after 5 years of at least one cold shower every 2 months,I trashed it and installed a 50 gal.for me and wife.
bukzin
04-20-2005, 12:30 PM
What do you suppose is the reason for the cold showers?
Was another fixture being used? Or???
Has your Dad had the same problem?
thanks,
Bukzin
sparks98
04-28-2005, 04:50 AM
Electric sucks. Do go with AquaStar's (Bosch) standard model. It doesn't matter how big the model, it's the demand. I have one and will NEVER go back to tank heaters. Higher demand, never runs out, cheaper on the gas bill and you'll never come home to a flooded area when it goes. They are rated for 35 years.
