Leaking from the Base
rtorrez
I noticed that some water was slightly leaking from the base of the toilet. After having the wax ring change twice it continues to leak. The catch, water only leaks when "sitting" on the toilet and it leaks before flushing. I noticed that there are also no leaks when flushed. The other thing that I noticed is that it only leaks when it has not been used for a few hours, sometimes just when used the first time in the morning. I also noticed that this happens AFTER we have some rain. Throughout the day there are no signs of water coming out of the toilet. Any suggestions?
First thing that comes to mind is: does the toilet move at all when you sit on it? If it does, you can keep putting new wax seals on until dooms day, wax isn't resilient, and when it rocks, will break the seal. The toilet must be sitting rock solid on the floor (use shims as required) for a wax seal to survive.
If the room is quite humid, it could be condensation running down off of the tank or a bad seal between the tank and the bowl. Resting against the tank might move things and allow a little seepage.
You're losing the seal somewhere under there. I would suggest you pull the toilet up and clean off the old wax. Then look at the flange. Does it set on top of the finished floor or is it recessed? If it is recessed, that may be the problem. A thick wax ring can compensate for a small recess, but you may need to add an expansion ring on top of the flange if the flange is setting deep. If it is solid on top of the floor, then set the toilet over the flange without a wax ring. It should set solidly on the floor all around. If not, it needs shimming. When you set the toilet with a new ring, make sure you set it straight down and don't slide it across the ring. Unless the toilet is broken, there should be no leaks if you do these things.
If you shine a flashlight between the tank and bowl, do you see any water there that could be leaking from the tank bolts or the tank to bowl gasket in the center? I had that problem with an old center gasket and after replacing it the dripping was gone. The drips were running down the sides of the bowl towards the back. Just thought you might want to check that out to at least eliminate the possibility. Over time the tank bolts can also become loose when the gasket compresses from the tank/water weight.
Edit - I realize you said it's from the base, but when I had the tank to bowl gasket issue it appeared to be around the base until I saw where the drips were starting from. Just a suggestion.
The water seems to flow only from one side of the toilet. A friend that is a plumber for a seminary school is coming over this afternoon and checking it out. THANK YOU all for your replies!!!!! Much appreciated!!!!:D
