View Full Version : Choice in waterheaters
casharon
04-07-2008, 07:40 PM
I am building a small (120 sq ft) portable cabin for a client. I am wondering about the pros and cons of using a 6 gal propane water heater vs an on-demand heater. Someone told me the 6 gal heater means very short/lukewarm showers, others say that won't be a problem. Obviously, the on-demand heater will be considerably more expensive, so I don't want to go with that option unless I have to.
Redwood
04-07-2008, 07:50 PM
I wouldn't be thrilled with a 6 gallon water heater... You may want to check out an RV water heater...
jadnashua
04-07-2008, 08:48 PM
You might get 2-3 minutes out of a 6-gallon WH in a shower if you were lucky, with it cooling off all the time. With minimal simulataneous fixtures, a tankless might work but if it is used in the winter, the incoming water might mean you'd need a bigger one than expected to get the temperature rise and flow you may want.
Where are you finding this 6 gallon propane heater? Is it a RV unit? It will give enough hot water for a quick shower.
Gary Swart
04-07-2008, 11:54 PM
A regular 40 gallon heater would be taller than the 6 gallon heater, but it would take up about the same floor space. Without actually comparing the prices, I can't make a definitive statement, but I would be surprised if there was a great difference in price. Seems to me that the price difference would be worthwhile considering the amount of hot water available.
master plumber mark
04-08-2008, 03:43 AM
If you are wise you will stay away from the
odd-ball propane heaters....
you can easily go out and get a 20 gallon or
30 gallon 110volt electric water heater
or better yet a short low boy 30 or 40 in 220v...
and rid yourself of any future troubles with
that small propane unit...
