View Full Version : Triangular toilet. triangle tank Eljer
pipehacker
04-07-2008, 07:47 AM
Does anyone have any thoughts, recommendations or experience concerning triangular shaped toilets and a good one to buy? Thanks.
FloridaOrange
04-07-2008, 07:55 AM
Don't sit on the pointy end....
:D Hope that helps.
04-07-2008, 11:03 AM
Only Eljer makes toilets with a triangle tank.
If they stop making them, then replacements are going to be a bugger.
http://www.americanstandard-us.com/assets/documents/amstd/spec/SpecSheet_2586.pdf
http://www.terrylove.com/wc/as/titan_corner_rough.jpg
Redwood
04-07-2008, 01:22 PM
Seeing as there is no competition in the marketplace I recommend sitting down while getting the price. Personally I would not set up a bath for one of these.
gizza job
04-08-2008, 11:33 PM
corner toilets are great for small bathrooms and work as well as a normal one but you will probably need a flexible pan connector to get the waste away which can make the finished installation look untidy
What in the world would that be? the drain opening in the floor is positioned where it has to be without any "flexible pan connector".
04-09-2008, 10:32 AM
Rough in for a corner toilet is 12" out from both of the corner walls.
Rough in for a standard toilet is 12" from the back wall, and at least 15" from the left wall and 15" from the right wall.
sjsmithjr
04-09-2008, 11:39 AM
I got curious and googled it.
"OPELLA’S MULTIFORMEŠ wire reinforced flexible pan connector can adapt to almost any kind of situation where a toilet needs to be re-sited, without affecting the flow of waste. A unique flexible helical design offers smooth internal surface allowing rapid disposal of waste. Expands and contracts between 280 mm / 11" and 550 mm / 21.1⁄2" in length. Stays in position once bent, but can be easily repositioned if required. Suitable for 100 mm / 110 mm diameter. Can be used long or short, for bends or offsets. No adhesive required, push fit connection."
http://www.thomasdudley.co.uk/images/productImages/rigiflex/rigiflex.jpg
Needless to say, plumbing is a bit different on the other side of the pond. Can you imagine trying to explain that to the AHJ?
-Sam
I would like to see how a "unique helical" design could have a "smooth interior". Then that "neck" just below the connecition point would be an interesting restriction. And the "push fit connection" would be a handyman's dream. They can hook the toilet up and then push it around the room until they find a spot where it looks good.
Redwood
04-10-2008, 06:21 PM
I'm sure that would pass here... Like when pigs fly!
Wally3433
01-18-2012, 12:54 PM
I am trying to figure out if this toilet will fit my rough in.
The diagram below has me confused though. I can understand that the rough in is 12" from finished wall to center of outlet. But what is confusing me is what appears to be offset bolt locations for the flange? There are two bolt locations shown 18.5/8 from the front of the bowl? Or are these the bolts for the seat?
Has anyone installed a triangle toilet? Other than the obvious, is there any differences or items to note for the installation?
http://www.build.com/mediabase/specifications/specsheet2588v2.pdf
01-18-2012, 01:18 PM
The 18-5/8" measurement is for the seat.
Rough is 12" from the corners.
AcidWater
08-16-2012, 07:37 PM
You could jury rig the 5 gallon carboy from a water cooler.
That flexible pan connector doesn't look like it would survive an encounter with the Roto Rooter man.
