View Full Version : Generator .... any good?
Entropy
04-07-2008, 07:31 AM
Good Day,
I bought a TQ 3000 watt generator at Walmart yesterday. I plan on using it only for emergency power for my sump pump and possibly freezer, perhaps at times my sewage pump or well pump.
I relize I could only power one pump at a time with this generator.
It says it's a 3000 watt max and 2700 watt continuous.
Does anyone know if this brand is junk, or will it meet my 'emergency' needs.
Do you have one ??
Thanks,
Entropy
Bob NH
04-07-2008, 02:12 PM
Can't find the TQ 3000 but there is a TG 3000 by Eastern Tool.
http://www.easterntools.com/product_detail.asp?ProductID=6
http://www.amazon.com/gp/product/B000P9SOKY
The question is whether it will meet your needs. You may want to do a little cooking and have a few lights. You will have to carefully manage the load.
I have no information on the brand. However, I usually consider that heavier is better and it is a pretty light generator.
If it is the TG3000 then it is reated pretty quiet, which is good.
Ian Gills
04-07-2008, 02:33 PM
I go the battery backup route for my sump pump. Depending on how much use it will get there are cheap and effective options for this.
I would keep the generator for the other stuff on your list which impacts upon your personal comfort more. In the dark, and thirsty, your wife will have little sympathy when you tell her the gen is being used for the sump pump!
Plus, you need to be in to fire the thing up!
04-08-2008, 06:31 AM
The power output is usually not regulated so I would not use it for sensitive items such as a computer.
Entropy
04-08-2008, 07:46 AM
Ya, it is the second one but only paid $250 not $382 (wow!!! that's a lot more). This is bigger than the 1200 watt one I had bought from Canadian Tire. I returned it and got the one from Walmart. Same price but almost 3 times the capacity.
Entropy
Entropy
04-08-2008, 07:47 AM
Would my hige ef. gas furnacer count as sensitive?
Entropy
Furd
04-09-2008, 01:06 PM
A high efficiency furnace has solid state electronics for control purposes.
So the answer is yes, this could be a problem with this generator.
You could get a voltage compensating transformer but it would likely cost as much (or more) as the generator itself.
mikept
04-09-2008, 05:43 PM
What about those battery UPS (untinterupted power supply). Those are fairly cheap and woudl give you minutes to use you computer before having to turn on the generator and could protect your computer from voltage issues or spikes. Alot of computers arent that sensitive and have ranges from 90v to 250v and frequencys bewtween 40something and 60somethign Hz.
Entropy
04-10-2008, 07:54 AM
I have no need to power my PC (computer), but it sounds like I might be able to use my deep cycle batery from my boat and my 700 watt power inverter to power my furnace once in a while if needed.
But with a wood stove in the basement it would be a pain to do simply for the "luxury" of it. The wood stove would look after us well.
Entropy
Furd
04-10-2008, 10:04 AM
Most (probably all) UPS systems under $100 have no line conditioning, they do not correct for low voltage but simply switch to battery power when the voltage dips.
A 700 watt inverter most likely has a "modified sine wave" output and would be hard on the circuit board and motors in a high efficiency furnace.
shag_fu
04-10-2008, 02:21 PM
You might have saved money by buying a better more complete generator as a package. Ive installed about a dozen residential generacs in the last year. They arent the best but for a solid, reliable and plentiful power supply in an outage, its hard to beat for the price. They are also simple enough they can be installed with just a handful of basic plumbing and electric knowledge.
BigLou
04-11-2008, 04:26 AM
Entropy,
you purchased this unit from wall mart (driving down quality as well as prices) so I hope that quality was not a large part of your expectations. however in a pinch it will run things like your sump pump. does it have a 220 out put? most well pumps I have seen are 220 volt also how would you plan on wiring it in ?
enosez
04-11-2008, 05:49 AM
Basic Plumbing Knowledge to instal a generator?
04-11-2008, 07:38 AM
He is assuming a natural gas powered motor, I suppose
shag_fu
04-11-2008, 02:48 PM
natural gas or propane, for a constant power source as opposed to diesel which you would have to refill.
frenchelectrican
04-29-2008, 01:08 AM
Not always the case it don't matter which type of fuel one way or other the fuel supply can be inturppted.
with natrual gas there is some chance you can actally loose the NG supply on widespread power outage.
now with LP [ Propane ] it pretty much depending on how much fuel you have in the tank and if you run out small units it can able but not always the case but use the BBQ tank [ not all will have that fitting on hand ]
Diesel fuel they are pretty good if you store the fuel right and IMO it is little more easier to find the fuel during power outage because many larger filling station whom have stand by generators they can able pump diesel fuel for your generator.
Merci,Marc
