View Full Version : Inline Water Pressure Pump
maverick30900
04-06-2008, 12:11 PM
I water my lawn via my two outdoor faucets and I would like more pressure so i can run multiple sprinklers off one faucet and a single sprinkler off the other faucet. I am looking to boost pressure from the faucet to run multiple sprinklers. Is there a pump I can connect to this faucet to boost pressure?
jimbo
04-06-2008, 03:41 PM
The problem is not so much a pressure issue as a volume issue. The hose bibbs you are using are likely fed on 1/2" pipe, which means about 5 to 7 gallons per minute is all you can get. If you try to "suck" more water using a pump, the water velocity in the pipe and the pressure loss within the source piping will increase dramatically.
The proper course of action is to source the sprinkler system from a point in the water supply system closer to the meter...from a large pipe.
