View Full Version : turned around hot&cold
nan
04-16-2005, 02:01 PM
so if i moved a water heater (temporary) to another space and hooked everything up then realized that i had the hot and cold water pipes swiched would it matter that much?? would it just run everything backwards?? this is just a temp move for a few days
any advise?
thanks nan
Plumber2000
04-16-2005, 02:07 PM
If you like hot water to the toilet, hot water to ice maker if you have one, and all faucet reversed when turned on, then no it will not matter,
04-16-2005, 05:50 PM
It will have no effect on the icemaker, faucets, or anything else. You WILL run out of hot water sooner since you will just be using the lower third, or less, of the tank's hot water. Just criss/cross the connections if you used flexible connectors to install it.
nan
04-17-2005, 07:50 PM
thanks for the helpful info hj :)
nan
