msehler
03-23-2008, 06:53 PM
I have a quick question.
To start, I am not very versed in plumbing. I have just bought a house (1975) which has all copper pipes. I have soldered on new washer/dryer valves (with extensions), as well as replaced the main seal and drain valve that comes right off the main.
The kitchen sink (not aware of brand...I am at the apartment right now) is a chrome fixture, two handled. It is the only fixture I am aware of that does this. When the water is turned on it "jumps" rythmically (about once every second). It does it with both the hot and cold water. What causes this and how do I stop it? It seems to lessen and almost go away when I turn both hot and cold full blast.
I don't believe it's air in the lines as I have now went to every water outlet and used it.
The only thing I can think it might be is some gunk/etc in the aerator (haven't had time to check...the whole family came up for easter and helped get beds set up). What else should I check?
Thanks,
-Matt
Thanks,
-Matt
