View Full Version : Would like to use PVC
DoubleD
03-19-2008, 06:22 AM
I'm installing a basement bathroom. The current water lines are 3/4"(I think for cold) and 1/2" for hot. The existing lines are copper. I would like to tap into the copper and convert to CPVC. What size should I go with for each? I'm putting in sink, toilet, and shower.
Thanks
Dennis
You are not going to gain much by increasing the sizes unless there are long distances involved.
DoubleD
03-19-2008, 06:29 AM
The distance is not long. Can I use 1/2" CPVC for both? Will I lose anything going from 3/4" to 1/2" on the cold?
Mikey
03-19-2008, 07:29 AM
If the distance isn't too great, you should consider staying with copper. The transition fittings (CPVC<->Copper) are pretty pricey. Either way, 1/2" should be fine.
Gary Swart
03-19-2008, 08:03 AM
The inside diameter of CPVC is smaller than the same size copper pipe. You would be wise to stay with copper.
prashster
03-19-2008, 08:21 AM
I converted to cpvc for a tap off my mains to a bar sink. It worked pretty well. I found that Price(transition coupler + cpvc pipes) < Price(copper pipe).
I also considered PEX because of ease of installation. However, for a small job, the price of the crimper blows the calculation.
DoubleD
03-19-2008, 10:48 AM
Thank you.
Gary Swart
03-19-2008, 01:50 PM
BTW, your thread is titled. "Would like to Use PVC". In the body you say CPVC. I trust you know the difference and that PVC is not allowed for inside water supply lines. CPVC is of course, but I'd still stay with copper.
DoubleD
03-19-2008, 02:31 PM
I know the difference. However, I thought that CPVC is a "kind" of PVC. Hence the title.
I am using all CPVC. But can you use PVC for cold water?
Thanks
Gary Swart
03-19-2008, 02:56 PM
No PVC for water supply inside the house. Yes, CPVC is a kind of PVC, but it has different chemical properties and requires different solvent. (glue)
DoubleD
03-19-2008, 08:51 PM
Thanks for the info.
Where can PVC be used?
Gary Swart
03-19-2008, 11:28 PM
Inside it can be use for drain lines. Outside it can be use for the main supply line to the house and for sprinklers.
I agree with the other opinions here if your run isn't that long stick with copper.
1/2" for the fixtures described will be fine.
