I have a single handle shower valve. When I turn the shower on, the PBV begins to vibrate loudly (about 4 hz) and the water pulses. It started about 1 year after I installed it. It only happens when I turn the hot water on. If I turn on another valve, it will stop.
I have drained and charged the lines and changed the cartridges twice. Finally, I just cut the whole valve out and re-piped in a new one (different make - Price Pfister). As soon as I turned the water on it started again. I then took the cartridge out and cleaned it, still vibrated. The pipes are secure and don't rattle. I can't see a noticable difference in pressure from hot and cold. The pipes are copper and I use city water. I have no other problem with any other valves.
Does anyone know what causes this or how to fix it?
