View Full Version : Installing a 4 inch mini widespread faucet
Cybermonkey
03-16-2008, 10:09 PM
I am a bit confused on how to install a widespread faucet onto a 4 inch lav sink. There doesn't seem to be enough room between the spout tee and the supply shank. Do I need to buy an adapter? or just not seeing the obvious?
Thanks
--edward
jimbo
03-17-2008, 07:43 AM
Is it for sure a MINI widespread? The minis I am familiar with are actually one piece below the counter top. If it is a mini, and 3 piece, you might have to rotate the tee and the valve bodies. What make and model do you have? Picture would help/
03-17-2008, 09:00 AM
The conventional 3 piece wide spread faucet will not fit a 4" drilled sink. A true mini-wide spread has a one piece body under the sink and the trim pieces on top are sized appropriately.
