View Full Version : installing joist header
econguy
03-16-2008, 06:19 PM
Hi
I installed a joist header that spans 2 joists bays. The tail joist was previously sistered, as was one of the trimmer joists. Because of this, I used doubled headers. However, the other trimmer joist was only a single, and I didn't think to double it up.
Both headers are within 3' of the joist support, and the header is less then 6' long, so I could've used a single header/trimmer.
So my question is - I used joist hangers for every connection (tail-header, header-trimmer), along with 16d nails. They stick out past the single trimmer. Is this ok? I could see it either way...the situation only called for singles everywhere, so I should be fine even though I made the header stronger than necessary, OR since I used a doubled header, I should've used a doubled trimmer.
Thanks
AZ Contractor
03-16-2008, 11:05 PM
You lost me with joist headers, tail joists, trimmer joists and single header/trimmer.
Are you making up new words?
Phil H2
03-17-2008, 12:34 AM
Are you making up new words?Look at UBC 2320.8.4, IRC R502.10, or IBC 2308.8.3. All have similar language. The IRC seems the most conservative by specifically saying a single header. See R502.10 on this link http://www.cbs.state.or.us/bcd/boards/rsb/boardpack/07/100307/public_hearing/ch_05.pdf
Single trimmer joists may be used to carry a single header joist that is located within 3 feet (914 mm) of the trimmer joist bearing. When the header joist span exceeds 4 feet (1219 mm), the trimmer joists and the header joist shall be doubled and of sufficient cross section to support the floor joists framing into the header.
econguy
03-17-2008, 06:38 AM
Hi Phil, thanks for posting the links.
I was off on the length of the header before a doubled-up one is necessary, but mine is only about 30" long, so a single still would've been fine.
Any thoughts on my situation, whether to just leave as is?
Thanks again
Mikey
03-17-2008, 02:45 PM
Some joist hangers require their own nails -- regular nails will not meet their standards for warranty, code compliance, etc.
frenchie
03-17-2008, 08:05 PM
Is that from behind some pay-to-download barrier, or is there some website I should know about?
