Shower diverter problem
jeff2201
I am having an issue with a diverter on a bathtub faucet. The faucet is a one knob for hot/cold with the diverter knob on the tub spout.
With the faucet turned slightly so water is at a lower pressure, the diverter works normally. However, if I increase the pressure to the spout water will start to come out of the shower.
I tinkered with the diverter with no luck. Finally I removed the knob and diverter assembly from the spout altogether and I still had the issue of water coming out of the shower head. I'm scratching my head on this one.
Any thoughts?
Is this a new installation? If so, what kind of pipe did you use to make the connection? The manufacturers also often specifiy only to use one outlet on the valve and you need an el to route it up to the showerhead. If you use both outlets, it won't work properly.
If it an installation that had been working properly, and this just started, can't think of a good reason...maybe one of the pros can.
the shower worked before i remodeled it. I had to move some pipes to fit the new valve body and used copper. I followed all of the mfg (pegasus) suggestions on mounting/component locations. I get plenty of pressure so I don't think that it is a pipe problem. When i pulled the diverter, water only came out of the shower head like it should.
valve
Having "plenty of pressure" could make it a pipe problem. Depending on what you did to make the valve fit, you could have created resistance, or restriction, between the valve and the diverter to the point where the excess pressure/flow has to relieve itself up the riser to the shower head. In an extreme case you might have inverted the valve which would cause the same problem.
I remember that the valve body had the word "up" stamped on it for orientation, so I did a quick check and it is in the right position. I don't think I have a excessive amount of pressure, but I have been wrong before.
Referring back to the vague instructions I noticed that there are what screws on the valve body between the center and where the supplys attach. Pegasus refers to these as 'stops'. Is it possible that adjusting these might benefit my situation?
They are designed to shut the water off so you can service the whole thing without having to turn the house water supply off. Shutting them partially might create some noise, but you could try. As noted, those valves are often only designed to use one output...if you use the upper one for the shower and the lower one for the tub spout, if it is not designed for it, that will give you problems. You can pick up an inexpensive water pressure gauge for about $10. Might be worth checking.
the valve has a a connection for the spout and the showerhead. mfg instructions say to connnect to both.
mfg also says that pressure on hot and cold must be approx. equal for it to work properly. If that is my problem, any ideas on how i can check that without tearing out my newly installed tile surround?
valve
The valve itself should adjust for pressure fluctuations so that should not be the problem. If they sent a diverter spout, but did not furnish a "twin ell" then it was designed for the shower on top and the tub out the bottom. Your problem is more water than the pipe to the spout can handle and that is usually caused by the installer piping it incorrectly, but without seeing it or a picture we cannot diagnose the problem.
My new Moen shower valves specifically ask for 1/2" copper from the valve to the tub faucet/diverter. Apparently the back-pressure generated by CPVC, for example, is enough to cause water to be diverted up to the showerhead.
mine didn't specify. I assume you used copper and didn't have any problems. If you hadn't do you know of a way to take off some of the pressure short of tearing out the wall?
Try removing the entire spout. In theory, without the spout, you should get no water at the shower head.It may very well be that an obstruction may be in the spout tubing from the valve to the exterior part of the shower. IE: an MIP adaptor with too much T tape at the bottom of the valve output.
they only other possibility, if your pressure is above 90psi, it may cause both the spout and shower to open up.
