View Full Version : Need Easyboard And Redgard Help
Griff1n
03-15-2008, 08:42 AM
Using easyboard for the first time on a subfloor in a kitchen application.
Do you need to apply redgard to the wood subfloor?
Since the material is not the regular type of backerboard not sure if ok to just apply directly to the floor.
Thanks
jadnashua
03-15-2008, 06:17 PM
Redgard is (primarily) a waterproofing material...it does have a little antifracture capability, but not much. Nearly all CBU units require they be set in mortar and either screwed or nailed down using the specified fasteners. Normally, if you wanted to provide some waterproofing, you would do it on top of the cbu, not under it. Make sure to use the specified mesh type tape on the seams. You can do this while you tile...you are providing reinforcement, not making it pretty like on drywall. This ties the sheets together, helping prevent them from moving independently which can cause cracks along the edges of the sheets.
Before you do anything, have you verified the deflection of the subflooring is adequate for tile? Check out www.johnbridge.com (http://www.johnbridge.com).
Griff1n
03-15-2008, 07:19 PM
Thanks for your help!!!!!!!
Subfloor is perfect.. thanks
