View Full Version : proper venting
beretat
03-11-2008, 05:37 PM
hi
im basicaly learning as i go in renovation of our house, and just recently i learned how important is proper venting of c-traps(my main c-trap broke, whole lot of mess...fixed , dont wanna look back :eek: )
....anyway
i'm putting sink in new position in my bathroom...
on the pic is the situation in my bath, and intended drainage
can u let me know if my design would work?
or if there is better way to do this?
do i have to put extra vent branch for the sink?:confused:
thank you for any comment!!
krow
03-11-2008, 06:09 PM
Lets assume that the bathroom is on the top floor of your home.
First they are called P -trap
Second you cannot connect a sink drain to a shower P trap. They need to be vented and trapped seperately (There are sub sections in our code for different types of venting) But this is very basic set up that I drew for you
this will give you an idea of what to look for. Venting sizing and drainage sizing are also critical
03-11-2008, 06:37 PM
Essentially, you cannot do anything the way you have it drawn.
beretat
03-11-2008, 06:40 PM
sorry for my wrong terms p-traps sound better :o
your scheme would be ideal i know, but would require too much open walls etc., trying to save some labour...
so the option 1 would not work? i was thinking that the shower drain could work as a vent itself for the sink p-trap, just would add air to the drain system from my bathroom not from my roof... i guess it is crazy talk...
would option 2 work in my case? sink to the drain/vent branch is 56"
krow
03-11-2008, 06:53 PM
your second option would be ok, providing that the main stack is a minimum 3" diameter and the distance from each trap to the stack does not acceed 5' or 60"
krow
03-11-2008, 07:06 PM
Judging by your layout of the fixtures, I have no clue how you are going to have the sink drain stack vented when your stack is on the opposite wall. Within the 5' span you cannot have any change of direction excedding 135 degrees before it ties into the main stack
03-12-2008, 06:55 AM
Even if the shower is a minimum of 36" and the sink space also a minimum, you till may be exceeding the maximum distance you can run without having an auxilliary vent on the lavatory line. We all would like to be able to install piping with a minimum of labor, and repair, but it is not always possible. If you did it like your original drawing, you might as well just drill a hole in the side of the shower and run the sink into it. It would be the same thing, but require a lot less time.
jadnashua
03-12-2008, 08:19 AM
Code calls for the shower drain to be 2". You have it listed as 1.5"...while you may find a prefab shower with a 1.5" drain, it is not code compliant anywhere in the US.
beretat
03-12-2008, 02:23 PM
uhhh too many labor unfriendly informations :o
sorry my second picture says 'main stack' what i meant to say was the branch of main stack...
and that means trouble right? it seams like that branch 1.5" is meant to be use for one p-trap and ONE p-trap only is that the rule?
ok the whole story is like this... this bathroom was too small for 4pcs, there was bathtub ,toilet and sink right in the way when u open the door, so we decided to make some changes, use existing drain and cold,hot water of bathtub for the corner shower and just add sink in the corner, and keep toilet on the same spot...
easy say but there is too many problems with this right?:(
it is in bungalow and the door has to stay in the same spot...
would anybody thought of better layout of given drain pipes?
thank you
gmt
03-12-2008, 06:37 PM
What are the dimensions of the bathroom?
