View Full Version : Wife want more hot water!
Marty 1
03-10-2008, 05:38 AM
Ok, here's the situation: With our 40 gal. hot water heater, sometimes, when you're in the shower and the washing machine is on, the water in the shower gets cold. How, we've added another bath with a shower and my wife wants more hot water so that two people can take a shower with the washer going and not run out of hot water. Could this be done with a 50 gal. hot water heater? I know it depends on the length of showers, etc., but what do you think--can it be done? Thanks--Marty
cwhyu2
03-10-2008, 05:58 AM
Yes it can be done,but I hope you have deep pockets.Shower heads
dispence 2.5 gal per min,so an eight min shower uses 20 gal of water,
add two showers plus clothes washer at the same time:eek:you would need
two 50 gal w/h run in a series.
master plumber mark
03-10-2008, 06:12 AM
put in a 50 gallon and you will be happy....
Put in a 75 gal and the nagging will be silenced forever....
also install the shower heads that use less water....
the 50 gallon will work great unless their is some
sort of need your wife might have to make you jump through hoops for her....(thats another issue altogether)
The 50 will work fine with 2 people in the shower at the same time, absolutely.....
but if she trys to run out of hot water by
doing a load of laundry at the same time. and expecting two people to shower along with that....
you are in for nothing but greif....
you are on a slippery slope here and its best to
nip this in the bud early..........
Cookie
03-10-2008, 06:41 AM
I can't resist this one, lol,
Get a new wife. :D it might be easier.
cwhyu2
03-10-2008, 07:01 AM
Take your showers together it will be more fun.:D
Knowing whether it is a gas or electric water heater would make a recommendation easier.
alternety
03-10-2008, 10:17 AM
I you happen to have a boiler for a hydronic heating system, an indirect DHW tank using the boiler would also be an option.
rudytheplbr
03-10-2008, 01:11 PM
If you're using electricity to heat your water. you may be money ahead to install an "on demand" w.h. There are several different Co.'s making them, but the Co. advertised by Paul Harvey may be the best.
Good luck,
Rudy
Lakee911
03-10-2008, 04:01 PM
That is if you don't need to upgrade your electric service for one. I've seen some fairly hefty ones around here for the amount of temperature rise we need.
Lancaster
03-10-2008, 07:31 PM
Rinnai,the company that Paul Harvey (and Rush Limbaugh) advertise,only makes gas-fired tankless heaters.
Marty 1
03-10-2008, 10:09 PM
Hi: The water heater would have to be gas (we loose power here a lot), and I'm not so sure I want to go with an on demand heater, so I think I'll upgrade to a 50 gal regular hot water heater. Tonight, when I got home from work, I checked the setting on our current heater, and although it was set above HOT, it was just a hair over the A setting. That makes me think there might be hope for a 50 gal. heater if I crank it up a bit. Space might be a problem too, since it's got to be in the same closet with the furnace, and I only planed for an 18" 40 gal. hot water tank. Hopefully, it'll go in there. Marty
PS. I need a spell check badly--Is there one here somewhere? Thanks
Cookie
03-10-2008, 10:58 PM
Yes, their is Marty. Where you type to post a message, in the upper right-hand corner there is a check mark with the letters ABC above it. Click on that and that is the spell check. If you run your cursor over it, it will actually say~~check spelling.
But, I think your spelling is fine.:)
Bill Arden
03-11-2008, 03:43 PM
I use firefox and it spell checks automatically.
