abright52
Electrical Engineer
I recently bought a home that was built in the late 1930's. There are 3 drains going into the basement floor. I believe the main is 4" that connects to the city sewer. There is a 2.5" cast iron that runs into the basement floor and goes over to the 4" Main and there is a floor drain between the two.
I had a clog between the 2.5" and the floor drain. I ended up having to remove the 2.5" CI that went into the concrete to clear the clog. This pipe had a flanged end with what looked like some type of packing and lead filler to seal it up. After removing the lead and packing it pulled right up.
Now that it is removed, I would like to replace it with PVC. The hole in the floor measures 3" in diameter. What do I need to adapt the PVC to this hole and seal it up?
I currently have 1.5" coming down from the Kitchen Sink and Dishwasher into that drain. I will also be adding a wye for a sink in the basement and a wye for a washing machine drain. Any advice on sizing the remaining pipe would be appreciated.
