We recently started a bathroom remodel and for the shower my wife wanted to replace our current showerhead with a shower system. Below is what we have in our possesion now.
Moen 263ORB Double Handle Vertical Spa with Moen 3320 1/2 Inch Rough In Valve
After doing some research and finding that we will need a bigger (or 2nd) water heater to supply the system, I have another question and after searching for hours haven't found the answer.
Right now, our supply lines for the hot and cold to the shower valve are 1/2". Our master bath is on the lower level and the water heater is in the attic above the second floor (texas home). Replacing the supply lines with 3/4" copper is impossible due to the lines being behind existing drywall on the 2nd floor(don't need another project). We have never had a pressure problem in the house. We can shower, have the sink running and flush the toilet with no noticeable drop in water output. Will the 1/2" supply lines be able to adequately supply enough water to have the shower on and the 4 body sprays(out to 4-5 feet or so) at the same time??
All of the inlets on the valve are 1/2" and the body sprays are 1/2". I will be installing a pressure balance loop as recommended by moen for the body sprays.
Hopefully I didn't leave anything out...
Greg
Greg
