View Full Version : rotary hammer newb
mikept
03-07-2008, 02:45 PM
Its my first time using a rotary hammer.
I need to drill holes in cinder block and also concrete so i bought a $45 1" sds rotary hammer drill kit off of (the big auction site). It looks like the harbor freight one but is blue instead of orange.
I tried drilling the cinderblock first. It doesn't seem to do anything to the block till i push enough pressure on the bit then the drill kicks back at me and tends to chip the cinderblock.
Whats going wrong?
Spaceman Spiff
03-07-2008, 04:48 PM
Sounds like it's working fine. Cinderblock is reall soft and the rotary hammer is meant to drill holes in concrete... FAST! so... in soft cinder it will do it like butter. chipping and flaking is part of the game. unless it is solid grouted I just use my mason hammer and blow a hole in it. too much time to break out the Bosch and i need to seal around the pipe anyway.
The bit will only rotate until you put pressure on it then it will start hammering too. It will kick and grab so hold on tight... and have fun making the messes!
mikept
03-07-2008, 05:58 PM
yea im having fun
I'm starting with the tapcons so i'm mostly drilling a lot of small holes right now. I use the rotation only setting to get a little start(no chipping) and then add the hammer using just the right pressure so its going through like butter but the jumping is controllable. Its working fine and pretty fast. Later i'll try it out in the real concrete to see how its supposed to work:)
