My home was built in 1957 and the tube drain needs replaced. This area is very hard to get to...I only have a very small door outside the house--where you can only stick one arm inside, but can't see what you are doing. I can not access the pipes from inside the house, unless I cut a big hole in the drywall thru the master bedroom.
This tub drain is in extremely need of replacement. Is there an easy way to do this without. Iam pretty savy about home improvement, but thison has got me stump!!
Any help wil be appreciate it...
Thanks
hern615
