View Full Version : Low water pressure after installing filter/softener
EricRLarson
04-11-2005, 10:57 AM
Hello folks,
I just installed a water filter and a water softener, and we have noticed a significant drop in water pressure. Additionally the showers now whine because there is not enough pressure to close the valve completely.
I have isolated the issue to the filter. If I put it in bypass mode then it is fine, when I engage the filter again the pressure goes down. I notice this most in the kitchen sink and in the bath tubs.
I installed a GE GXWH20F filter housing and it has the default FXUSC filter in it, which filters down to 5 microns.
The pressure dropped as soon as we installed the filter.
Is there anything we can do short of removing the filter to get our water pressure back?
We have a well not city water.
Thanks,
Eric
What is the on/off pressure setting at now?
Just because a filter has 3/4" pipe openings on it, does not mean that it has the capacty to handle a whole house system. Apparently that filter housing or cartridge creates a huge pressure drop. You may not be able to use that filter and still have good pressure.
master plumber mark
04-11-2005, 05:20 PM
anything made by GE is junk.
If you bought a water softener from them from some hardware store outlet
you might live to regret it. They are low end units
possibly go to a plumbing supply house and get another filter that a plumbewr would put in and see if this does not do the trick.
Gary Slusser
04-11-2005, 06:06 PM
Hello folks,
Thanks,
Eric
The answer to the question is no, but, depending on what type of filter it is, you can get a filter that has a higher flow rate. So what is the filter used for, sediment or taste/odor? If taste odor it's carbon but they usually aren't stated as x micron unless they are a carbon block. They can't be used 'whole house' because they can't flow more than a .5 to a few gpm if that. If it is sediment, then check to see if it's not plugged up already. My money is on it being a carbon block.
Gary
Quality Water Associates
mrjetskey
04-12-2005, 07:03 AM
Years ago when I was on well water.We installed a settling tank, filter,then another separate pump to pump water through the softner into the house.This second pump only ran when a faucet was opened and it had a separate pressure adjustment switch so we didnt have to crank the pressure up on the well pump and wear it out quicker.just a thought!
EricRLarson
04-12-2005, 08:41 PM
Gary
Hello Gary and others,
I figured out what the problem was. The filter is actually going to be fine, the cartridge that was in it was defective. It is a rolled paper(?) filter and one or two layers had com free in the center of the filter, blocking the flow of water out of the filter housing.
This is just a sediment filter, and I replaced it with a carbon paper filter, which we do not really need, but it is all I had in the house (we will go back to just a sediment filter later). Now my water pressure is back and everything is great!
Thanks for your input everyone.
Eric
