mikept
03-04-2008, 01:29 AM
I found water pouring from the downstairs bathroom exhaust fan grille straight down into the lav last night when my father took a bath in the bathroom above.
I subsequently unscrewed the drain overflow plate (lever one) and sure enough the overflow gasket is hard and full of cracks and messy. I bought a replacement and pull the old one, well i tore it out in a bunch of pieces.
Unfortunately I cant get a new one back in there. Theres a bit of a gap on the top side but zero space on the sides and bottom. I pushed the metal drain pipe back quite hard but i couldnt get enough space to push the gasket in. If i had a thinner gasket i might be able to do it, but doubt it. I dont have easy access to the other side.
Can i clean it up good and use silicone cualk in there to seal the tub/overflow gap?
Is there a trick i dont know about?
Luckily i take mostly showers lol.
