Hi, I need to correct the way my storm water is draining from my home and I need some advise on how do it properly.
Current Situation:
Storm water collected in tile and sucked out with sump is going 100% into sewer connection. I am pretty sure this is an illegal connection as clean storm water is getting treated. The previous homeowner also had a bypass hooked up so you could shut it off to the sewer, and run it directly outside where he would hook up a hose to the connection and drain it into a rock bed. The problem with this connection is, it froze up and now leaks when I try to use it, so now I go 100% into the city sewer.
I would like to come up with a better solution, but I do not know what is typical when hooking up tiles for drainage. I have an abandoned septic tank, and I would like to run some waste lines from my sump in the basement, out to the septic and dump the ground water into it. The problem is how do I do this without keeping the pipes from freezing again when they go outside above ground before they go back underground. My sump runs in the winter about once a week so I need to be able to drain to the outside all year around. Is there some kind of check valve that gets used to keep water from being outside when not in use?
Any suggestions, help or plans you could provide me would be greatly appreciated.
Jeff T.
Michigan
Current Situation:
Jeff T.
Michigan
