View Full Version : Peerless single handle faucet tub leak
MrFyr
03-02-2008, 12:28 AM
I have a leaking Peerless single handle tub faucet. How do I fix it, please?
Thank you
krow
03-02-2008, 12:56 AM
Where is it leaking from?
I assume its dripping out of the spout. What model # is it?
MrFyr
03-02-2008, 02:37 PM
It is leaking from the spout and I don't know what model it is
except that it's over 20 years old. Is there a way to tell the model?
I didn't see any markings.
Thanks -
krow
03-02-2008, 05:35 PM
Does the handle turn to the on position or pivot to the on position.?
MrFyr
03-02-2008, 07:37 PM
The handle pivots (up/on and down/off) and turns for temperature (r/hot, l/cold).
krow
03-02-2008, 08:53 PM
This valve should have a ball type stem.
Shut off the main water to the house.Take the handle off. there should be a collar that unscrews. once the collar is removed, the ball will be visible and you can take it out carefully. On the inside of the valve body there should be washers 2 conelike washers and 2 springs behind them. Replace both washers and springs . Then reassemble pivot ball and collar.
Finish reassembling the handle
Hope that works for you
Springs ans washers for this are available at home depot for Delta repair kit
krow
03-02-2008, 08:59 PM
. You may have something similar to this pic
MrFyr
03-03-2008, 11:36 PM
thank you my friend -
those instructions seem easy enough that even i should be able to succeed
and the photo you posted looks like an identical twin. i will give a go
very soon. actually, i'm quite excited. :-)
thanks again
03-04-2008, 07:22 AM
Peerless faucets use Delta parts, although at that age, the ball may be different than the one a corresponding Delta would have used. Be careful removing the retainer cap or you will twist the valve into two parts, and then you will have converted a simple repair into a major repair or replacement.
MrFyr
03-23-2008, 01:17 PM
i repaired the leak in good fashion thanks to you guys -
you are a life saver - and money in my wallet saver- :)
thanks again
MrFyr
thejeanbee
04-06-2008, 08:57 AM
Is there a trick to getting the retainer cap off the Peerless ball type tub faucet? I've removed the adjustment ring, but the retainer cap just isn't budging.
Thanks,
Jean
04-07-2008, 09:12 AM
Yes, you buy a new Delta retainer/cap with the adjusting ring. Then you carefully heat your retainer around its perimeter. Heat it a little then gently try to unscrew it with a pair of Channelock pliers. Keep repeating the heating and unscrewing until it finally frees up and it unscrews with no pressure on the pliers. I had one Saturday that the cap started to melt before it released, but it finally came loose. HOWEVER, I have had a couple of Peerless sink faucets that absolutely refused to come loose and those faucets had to be replaced.
