Hot water from cold faucets
JackStephan2000
I moved to this two story house 5 years ago. Ever since, I get hot water from the cold faucets for few minutes until the water gets cold again.
I removed the plug from the pump but the problem did not go away
I closed the hot water return valve to stop the circulation but the problem did not go away.
My installation uses a Grundfos UP 15-42 SF pump and it has a hot water return pipe. It seems to be professionally done at the time the house was built in 1991.
Please help.
It is possible that you may have a cross connection in a faucet somewhere. I don't know why that would be in a residential application . It usually happens on commercial installations where they choose to leave the faucets in the on position and the check valves fail.
If you have a hot water recirc pump it could be pumping so fast that you're actually heating the water in your cold water pipes. When you draw fresh cold water it purges that hot water and it gets replaced by cool fresh water coming in to the house.
Jason
I tried with the pump off and even with hot water return valve off and got the same problem.
krow,
I am sure hot water is going in the cold water supply but I still cannot figure out how would that happen.
What is a cross connection? Do you mean Hot water connected to the cold side and cold water on the hot side of a faucet? Why would that cause a problem in the whole line as opposed to only on that faucet I would get cold from hot and hot from cold? I am asking and being specific because I do have one such connection in my outdoor faucet, but before I make the change, I want to understand how would that cause a problem.
Thanks.
krow,
Thanks.
A cross connection is when a faucet allows the hot water to circulate into the cold side just by gravity. As I said earlier, it usually happens when faucet check valves fail. Your indicating that you may have a connection of hot an cold together and if you don't have check valves or shut off the hot side for your outdoor faucet, that could cause the circulating by gravity.
Depending on the proximity from your faucet to the possible cross conection or in a direction of flow or even from your hot water source (stranger things have happened)
Questions.
Does the water get hot or just warm?
Does it last a few min. or less than a min.? Have you timed it?
The pump is the issue. With the pump off and the return isolated, does the problem persist even after you have run enough cold water to clear out the line....does the hot return the next time you run the cold tap?
Questions.
The water runs hot not just warm. It lasts few minutes then I start getting cold. I shut down, wait five minutes, then the same thing happens. I never timed because there are so many variants that can affect the duration.
I doubt it's the pump, but to answer your questions, yes even after I empty the pipes, I shutdown the faucet for five minutes and open it back again and I get the same behavior.
I think you are right about the cross connection. What I am saying about the outside sink is that the hot water pipe is connected to the cold faucet and vice versa, I doubt that's the cause. Now some history. Before I moved to the house I did some repairs and installed a shower with a thermostatic valve, I think that's where the problem is because my wife says the problem is worse in her sink which is the closest to that shower. Another thing I noticed is when the pump is on, I get cold water for less than a minute followed by hot water for few minutes then cold. With the pump off, hot water starts immediately for few minutes then cold. This behavior I noticed in my sink near that shower. I think when the pump is on, it moves the hot water from the problem area continuosly and that is why I get cold then hot then cold. I think I should turn the pump off and see at which faucet I would get the worst behavior and that would be the nearest point to the problem.
Another reason I think it's the thermostatic valve is that recently the situation is worse and the shower does not get as hot as before even on the highest setting. Am I on the right track?
Can you feel supply pipes to individual fixtures? I.E. pipes in the basement.
If so look for the hot cold line.
You are on the right track . I suspect that valve may have a cross over. It doesn't happen often, but it does happen . Being a thermostatic valve, you may have stops or valves built into the shower valve, see if you can isolate that valve off and see if it makes any difference.
At this point , it will be trial and error to track down the cause of your problem
We got it!!
Why it's happening is strange but this is the story and the short term solution:
It turns out that the problem does not happen if we leave the thermostatic shower valve in the coldest postion, which we never do. We always kept the dial on the comfort showering temperature which we never got because of this problem.
So now, if I keep it on cold when not in use, the cold water is normal in the whole house. We just need to turn the dial to hottest just before we take a shower and turn it to coldest right after we finish a shower.
When I remove the decorative cover, I can see the valve. It has one little control screw on each side (hot and cold). They are both set to the maximum (out) position. Do you know what those control screws do and if they can be adjusted to fix this problem?
They are stops or shut off valves for your unit. They are for shutting off your unit to make repairs on the faucet.
When I turn them (inwards), they get to a point where water starts to come out from the screw location, should I keep going in until they are tight and the water stops? I stopped when I saw water come out and turned the screw back to its original loation.
Is it possible to fix the valve by replacing that center piece (the temerature dial) without breaking the wall to change the whole valve?
On the temperature control, there is a little button with a spring, I never figured out why it's there, can you please explain it to me?
On my valve, there is a safety stop - you can't get the thermostatic control turned past that mark unless you press the button in. I forget what the temperature mark where that is - I think it's 110-degrees F.
The packing nuts on the stops are probably a little loose and need a quarter turn to stop the leak.
You should be able to turn these slot headed screws in as far as they will go (don't over tighten) to shut off your faucet.
It hasn't been asked yet, but I need to know if the centre valve is only a thermostatic control or an "on / off" . Some units are only to control the temperature and not the on/off. Do you know what model it is? This will tell me what the botton with the spring is.
I had a chance to think about this.Do you have a spout on your shower? If not, that button with the spring could be diverter if the faucet was intended to be bathtub faucet with a spout.
No I don't have a spout. When I search the web for similar Temretaure control shower valves, most of them have this button. I think it might be for quarter turn lock increments but I am not sure because it never worked properly on my shower handle.
