View Full Version : How to remove drain cover mounting
Waffle
02-24-2008, 04:00 PM
One of our showers has a tile floor. The drain was improperly installed. The fitting for the cover sits on top of the tile instead of level with the floor or recessed. This creates a barrier to water flow, so we have to mop the floor after each shower.
Here's a photo:
http://i32.tinypic.com/jzu3s.jpg
The plastic around the outer edge is very brittle, but the center part is solid. How can I remove this fitting? It doesn't unscrew -- or at least not any way I've tried. The black drain below is ABS. I reached in and noticed a bit of a gap between the white fitting and the black ABS.
I figured I'd replace the white fitting with a snap-in drain cover that's level or below the floor and seal with good-quality silicone caulk.
Thanks
jadnashua
02-24-2008, 04:18 PM
As you've guessed, that is not the right drain for a tiled application. It also appears that the thing is not sealed to the drain pipe, either!
I don't know of any successful means to solve this problem without tearing some things up. It's unlikely that there's a liner under there as well (unless I'm all wet).
You may want to post this over at www.johnbridge.com (http://www.johnbridge.com) where they specialize in tiling and showers are a big part of it.
Waffle
02-25-2008, 10:30 AM
Thanks. I posted a message at johnbridge. We moved in only a few months ago and there are many projects with higher priorities than rennovating this bathroom so I guess we'll stick with mopping for at least a few years. I was hoping I could find a simple fix. Oh well....
