Polson
02-19-2008, 06:44 PM
I am replacing my kitchen counter and sink because they are in need of updating. My old sink was 6 inches deep and I would like to put in an 8 inch sink now. The problem is that the waste line coming out of the wall is too high, so an 8-inch sink is too deep to drain into the waste line, specifically on the side with the disposal. I would like to lower the waste line to allow for the deeper sink. My house was built in 1947 and the waste line is 1.5 or 2 inch steel pipe. As far as I can tell it comes straight up out of the basement and makes a 90 degree bend out of the wall under the sink.
Is it possible to cut open the wall beneath the 90 degree bend, cut a few inches off the steel pipe in place with a hacksaw or something and couple the cut end to a plastic line with some sort of rubber coupling or something?
What do you all think is the easiest way to solve this issue? I want a deeper sink, but not if it's going to cost me a ton of cash in plumbing changes...or flood my basement with wastewater;)
Thanks for the help.
