We had a GE Merlin RO water system installed under our kitchen sink due to high levels of nitrates in our well water. The system is supposed to work under water pressures of 40 to 80 psi during operation. However, our system commonly runs under the minimum 40 psi's (the system is not even guaranteed to work properly under these conditions) and even runs as low as 30 psi's at times. Besides the fear that these low operating pressures may be causing our RO system to not work properly (take the nitrates out of the water), the concentrate water continually runs to the drain after the faucet has been shut off and the noise is driving us nuts!! I've tried replacing the prefilter and postfilter (as recommended in the troubleshooting section of the owner's manual) but that didn't cure the problem. Knowing nothing about my Well-X-Trol WX-202, can I make some adjustment on the tank that would increase the pressure to our RO system? If so, is this what you would recommend and how do I do it? Or, is there maybe a pressure leak somewhere in our RO system, and I just need to call a plumber to help me find it. P.S. - the water pressure in the rest of our house is good.
