Bath tub hot water dripping
Wyodad75
Cheyenne, WY
www.wyomingwranglers.com
My hot water in the bath tub will not turn off. It is constantly dripping (will fill up a small cup in about a minute). I took the screw out and tried to take the hot water handle off to put a new washer, but the handle will not come off. It gets to a certain point and gets stuck. I have been told I need to “break the gasket,†is this true? Also, when the water to the house is off the hot water still drips, at a slower rate.
Please help!!! Thank you :confused:
Once you turn the water to the house off, you need to fully open a valve or two to relieve the pressure. Once you do that, things should stop dripping. Now, if this faucet is on the first floor and you have a second, then all of the water in the pipes upstairs is pushing down and needs to be drained as well.
If you can post a picture or supply a brand and model, then the people here can help you more. Depending on the faucet, you may or may not need to pull the handle.
A simple handle puller is available for about $10 at any hardware store. You can try spraying some white vinegar into the hole where the screw is , to try to loosen things up.
While you are shopping for tools, you will probably need a set of shower stem sockets and a seat wrench. These are also inexpensive, and available at the local hardware store.
Once we see a picture, we can probably tell you what parts you will need. If the brass is OK, you can just replace a flat washer, on most models, but will likely also need seats.
