View Full Version : Cleaning turbo torch tips?
Marlin336
02-17-2008, 04:31 AM
How do you guys clean these out? I've got a bunch of them that either have a horrible flame or spew black gunk all over. I finally ran out of extra tips and it's now either clean em up or buy new ones. I know you can remove part of the bottom with an allen key but where do you go from there? Soak it in diesel, tiny wire brush, etc?
For my torch tips I usually replace the filter with a new one and the flame will be as good as gold
master plumber mark
02-17-2008, 06:07 AM
I usually soak them in gasoline
How do you change a filter on one of those ????
Usually when all else fails I heat up the tip with another
torch and that will clean out all the debris and solder balls that get
inside one of them....
I never knew that their was even a filter that could be changed
srdenny
02-17-2008, 05:51 PM
Filters are on the bottom tof the tips. They come out with an allen wrench.
A tip that has hardened solder in it might require heating up to make it flow out.
Tip #57: don't lose the orifice when you take it out to clean it. :eek:
