1 1/4" drain to 1 1/2" wall inlet
Fubar411
St Louis, MO
I'm putting in a new lavatory sink. The sink has a 1 1/4" drain and the wall has a 1 1/2" inlet. What is the best way to do this? I bought a new 1 1/2" P trap, but the 1 1/4" drain seems to float in it.
Obviously, L0wes was not much help. I will be hitting a plumbing supply store tomorrow.
If you are using ABS pipe and fittings, you can pick up a 1 1/4 x 1 1/2 trap adaptor. The 1 1/4 side is a slip fit compression that fits over your 1 1/4 P.O. plug (Tailpiece)
Very standard product found just about any plumbing store , hardware store, lowes or HD
The key at Big Box is finding someone that knows what they are and knows in what illogical location they would be at.
Very true, I guess it makes it easier when you know what you are looking for and you don't have to ask for help from the associates :D :D
Plumbers typically buy 1.5" pvc p-traps with ABS trap adapters, and both the 1.5" and 1.5x1.25" slip joint washer in the bag together.
You should be able to get the 1.5" x 1.25" washer at the big box too.
Nice about being a plumbing and buying from plumbing supply's and not big boxes,
We get what "we" like to use
They don't put gummy stickers on everything.
The quality is better.
Thanks. It turns out I was using the right adapter all along. I was somewhat concerned as it didn't seem airtight (new pvc, I did a "blow" test, no jokes please!)
Worked out great.
So for a lav sink, do you usually stub out a 1 1/2" or 1 1/4" screw adapter?
. Code calls for 1-1/2 in the wall.
The codes in my area call for 1 1/4" through wall for a wash basin. Plumbers use 1 1/2" because its 1/3 the price per fitting.
1-1/4" fittings cost 3 times more in my area than the 1-1/2" fittings
Not a joke, but a question ... did you put your mouth on the open sanitary sewer pipe? :eek:
I am having a similar problem, but no matter what i do it always leaks.
I have 1 1/4" sink drain and 1 1/4" pipe sticking out of the wall.
because of the odd height angle and hight difference of my new cabinet and sink i have to use an acordion p trap but they only come in 1 1/2" so I used the adapter plastic rings and no matter what i do it leaks from the adapter to pipe in the wall. I tried leaving tightening it with a pipe wrench a little at a time till the plastic was stripped. tried a different one leaving it somewhat loose. I tried putting some rubber o rings on before the adapter ring. and i tried calking it with silicone and no matter what it always leaks.
I cant adapt from 1 1/2" to 1 1/4" and not have it leak. is there anything else i can do? Im about ready to take a hacksaw to the wall and replace all the pipe because i dont know what else to do.
please help!
Ryan
trap
Especially on the spigot of street fittings and bushings. Audion man, it is trying to tell you something, namely do not use that trap. Find a way to use conventional fittings to get the trap to line up properly.
it wont work with a normal trap because the sink drain is too close to the wall. the only other way i can do it without the accordian trap is to go to the side and use a 45 or two 90's to get back to the wall, but they dont make those in 1 1/4" either so it still leaks from the last elbow to the 1 1/4" pipe coming out of the wall.
